Ga door naar hoofdinhoud
Eclipse 180BL Battery Replacement
Wat je nodig hebt
  1. Eclipse 180BL Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: stap 2, afbeelding 1 van 2 Eclipse 180BL Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: stap 3, afbeelding 1 van 3 Eclipse 180BL Battery Replacement: stap 3, afbeelding 2 van 3 Eclipse 180BL Battery Replacement: stap 3, afbeelding 3 van 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: stap 4, afbeelding 1 van 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
Conclusie
3 andere personen hebben deze handleiding voltooid.
Thomas Schwarz
499 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 1,412
