Ga door naar hoofdinhoud
Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement
Wat je nodig hebt
  1. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Disconnect the spark plug: stap 1, afbeelding 1 van 2 Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Disconnect the spark plug: stap 1, afbeelding 2 van 2
    • Move the stop switch into the "stop" position to turn the pruner off before attempting any repairs.
    • Pull the spark plug cap straight off of the spark plug.
  2. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Remove the control handle assembly: stap 2, afbeelding 1 van 1
    • Use a T25 Torx screwdriver to loosen (but not remove) the two screws clamping the main pipe assembly to the control handle.
  3. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 3, afbeelding 1 van 2 Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 3, afbeelding 2 van 2
    • Remove the control handle from the main pipe assembly.
  4. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Disassemble the control handle: stap 4, afbeelding 1 van 1
    • Use a T25 Torx screwdriver to remove the seven screws holding the control handle together.
  5. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 5, afbeelding 1 van 1
    • Lift the top half of the control handle straight up to remove it.
    • The following step shows the throttle trigger and throttle lockout removed. These parts do not need to be removed for this guide.
  6. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Remove the control handle: stap 6, afbeelding 1 van 1
    • Use a T25 Torx screwdriver to loosen (but don't remove) the screw clamping the strap hook to the handle pipe.
    • You may need an 8 mm socket and socket wrench to hold the nut on the back of the strap hook while you loosen the bolt.
    • Remove the two T25 screws securing the handle to the handle pipe.
  7. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 7, afbeelding 1 van 3 Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 7, afbeelding 2 van 3 Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement: stap 7, afbeelding 3 van 3
    • Slide the strap hook off the pipe and remove it.
    • Slide both clamps that held the handle off of the pipe and remove them.
  8. Echo Power Pruner 254 cc PPT2620 2019 Flexible Tube Replacement, Remove the flexible tube: stap 8, afbeelding 1 van 1
    • Slide the flexible tube off of the handle pipe and remove it.
Conclusie
Adam O'Camb
196.731 Reputatie
416 handleidingen geschreven
Één opmerking
The photos and instructions are great, but a video on how to dismantle and reassemble would be better. still shots cannot show the nuances of the reassembly.
JANET - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 22
Altijd: 964
