Ga door naar hoofdinhoud
Echo Chain Saw CS590 2019 Front Hand Guard Replacement
Wat je nodig hebt
  1. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Turn off the chainsaw: stap 1, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Turn off the chainsaw: stap 1, afbeelding 2 van 2
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Loosen the air filter cover: stap 2, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Loosen the air filter cover: stap 2, afbeelding 2 van 2
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 3, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 3, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 3, afbeelding 3 van 3
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: stap 4, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: stap 4, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: stap 4, afbeelding 3 van 3
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: stap 5, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: stap 5, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: stap 5, afbeelding 3 van 3
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front handle: stap 6, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front handle: stap 6, afbeelding 2 van 2
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: stap 7, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: stap 7, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: stap 7, afbeelding 3 van 3
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the sprocket guard: stap 8, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the sprocket guard: stap 8, afbeelding 2 van 2
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 9, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 9, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: stap 9, afbeelding 3 van 3
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: stap 10, afbeelding 1 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: stap 10, afbeelding 2 van 3 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: stap 10, afbeelding 3 van 3
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front hand guard: stap 11, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front hand guard: stap 11, afbeelding 2 van 2
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front hand guard: stap 12, afbeelding 1 van 2 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front hand guard: stap 12, afbeelding 2 van 2
    • Pull the front hand guard toward the rear of the device to remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
164.606 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
121 Leden
19.765 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 66
Altijd: 1,204
