Inleiding
This guide shows how to remove and replace the both clutch shoes in an Echo SRM-2620U Brushcutter.
Wat je nodig hebt
Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Unclip the throttle cable routing clip from the main shaft.
Use a T30 Torx driver to remove the two screws securing the muffler cover.
Use a T30 Torx driver to remove the two screws securing the engine cover.
Use a T30 Torx driver to remove the two screws securing the fan cover.
Reroute the two control cables through the opening on the fan cover.
Lay the cables into their slot on the clutch cover.
Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
Use a T30 Torx driver to remove the two screws securing the clutch cover.
Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
Ensure that the clutch assembly is reinstalled arrow side up.
Firmly grip one clutch shoe in each hand and twist them apart to release the spring tension.
Disconnect one side of the spring loop from one of the clutch shoes.
Disconnect the spring from the second clutch shoe.
Remove both clutch shoes.
