Ga door naar hoofdinhoud
EasySMX ESM-9110 Vibration Motor Replacement
Wat je nodig hebt
  1. EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: stap 1, afbeelding 1 van 2 EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: stap 1, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Vibration Motor Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Vibration Motor Replacement: stap 3, afbeelding 1 van 1
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: stap 4, afbeelding 1 van 3 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: stap 4, afbeelding 2 van 3 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: stap 4, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • The screw extender should only be used to unscrew two of the six screws. Do not use it for all six.
  5. EasySMX ESM-9110 Vibration Motor Replacement: stap 5, afbeelding 1 van 2 EasySMX ESM-9110 Vibration Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle, the controller's backplate is still attached. Do not move the controller too roughly.
  6. EasySMX ESM-9110 Vibration Motor Replacement: stap 6, afbeelding 1 van 2 EasySMX ESM-9110 Vibration Motor Replacement: stap 6, afbeelding 2 van 2
    • Locate the parts of the vibration motor that are connected to the motherboard
    • Solder these parts of the vibration motor to remove them.
    • There should be two connectors present in your controller, one for each vibration motor.
Conclusie
Melanie Rodriguez
406 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-4, Konn Spring 2024 Lid van UMass Dartmouth, Team 2-4, Konn Spring 2024
UMASSD-KONN-S24S2G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 278
