Wat je nodig hebt
If you have any dust caps over the HDMI or Display Port connections, remove them
Remove the 3 screws using a Phillips #1 Screwdriver (Red)
Remove the 2 Standoffs using a 5mm socket
Gently slide the plate out from between the back cover and the circuit board. It should come out without much force.
If it doesn't want to budge, check that the right screw was removed from the top of the video card.
Using the 1.5mm Hex, remove the 4 screws (one on each corner) to release the shroud
Note: there is 4 screws on each corner plate, the other 3 screws do not need to be removed.
The shoud should be able to be lifted free easily, on the wiring harness for the lights.
The connector for the harness is on the inside end end, nearest the power connectors.
The connector can be disconnected to completely seperate the shroud, or left connected if just needing access to the fans.
Één andere persoon heeft deze handleiding voltooid.
