Inleiding
Follow this guide to replace the belt on an EDCO Floor Stripper TS8 .75L (2017).
Wat je nodig hebt
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
Slide the motor towards the front of the device to release tension in the belt."
Één andere persoon heeft deze handleiding voltooid.
