Ga door naar hoofdinhoud
Dyson v6 Absolute Cyclone Replacement
Wat je nodig hebt
  1. Dyson v6 Absolute Cyclone Replacement, Bin: stap 1, afbeelding 1 van 1
    • Unplug the device.
  2. Dyson v6 Absolute Cyclone Replacement: stap 2, afbeelding 1 van 1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Cyclone Replacement: stap 3, afbeelding 1 van 1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Cyclone Replacement: stap 4, afbeelding 1 van 1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Cyclone Replacement, Main Body: stap 5, afbeelding 1 van 1
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Cyclone Replacement: stap 6, afbeelding 1 van 1
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Cyclone Replacement: stap 7, afbeelding 1 van 1
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Cyclone Replacement: stap 8, afbeelding 1 van 2 Dyson v6 Absolute Cyclone Replacement: stap 8, afbeelding 2 van 2
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Dyson v6 Absolute Cyclone Replacement, Cyclone: stap 9, afbeelding 1 van 1
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Dyson v6 Absolute Cyclone Replacement: stap 10, afbeelding 1 van 2 Dyson v6 Absolute Cyclone Replacement: stap 10, afbeelding 2 van 2
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Dyson v6 Absolute Cyclone Replacement: stap 11, afbeelding 1 van 1
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Tabitha Espina Velasco
3.594 Reputatie
5 handleidingen geschreven
2 opmerkingen
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
John Griggs - Antwoord
Das Zyklon läßt sich noch viel weiter zerlegen!
Tom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 205
Altijd: 20,462
