Ga door naar hoofdinhoud
Dyson v6 Absolute Battery Pack Replacement
Wat je nodig hebt
  1. Dyson v6 Absolute Battery Pack Replacement, Bin: stap 1, afbeelding 1 van 1
    • Unplug the device.
  2. Dyson v6 Absolute Battery Pack Replacement: stap 2, afbeelding 1 van 1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Battery Pack Replacement: stap 3, afbeelding 1 van 1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Battery Pack Replacement: stap 4, afbeelding 1 van 1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Battery Pack Replacement, Battery Pack: stap 5, afbeelding 1 van 1
    • Locate the screw on the battery pack.
    • Use a Phillips #2 screwdriver to unscrew the battery pack.
  6. Dyson v6 Absolute Battery Pack Replacement: stap 6, afbeelding 1 van 1
    • Locate the screw on the device handle.
    • Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
  7. Dyson v6 Absolute Battery Pack Replacement: stap 7, afbeelding 1 van 2 Dyson v6 Absolute Battery Pack Replacement: stap 7, afbeelding 2 van 2
    • Pull the battery pack down and away from the device.
Conclusie
137 andere personen hebben deze handleiding voltooid.
Tabitha Espina Velasco
3.594 Reputatie
5 handleidingen geschreven
30 opmerkingen
very good article 10 out of 10
karl thiele - Antwoord
Nice article. Not too long or too short. Perfect pictures, too.
timlevin - Antwoord
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Meg Olhasque - Antwoord
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
Ellymck - Antwoord
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Beverley Mingo -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 63
Afgelopen 7 dagen: 398
Afgelopen 30 dagen: 1,695
Altijd: 279,904
