Ga door naar hoofdinhoud
Dyson V8 Absolute Battery Replacement
Wat je nodig hebt
  1. Dyson V8 Absolute Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dyson V8 Absolute Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Detach wand from device.
    • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
    • Screw Head Type: Phillips #2
    • Screw Length: 170mm
  2. Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 1 van 3 Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 2 van 3 Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 3 van 3
    • Turn device completely over to view battery pack.
    • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
  3. Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 1 van 3 Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 2 van 3 Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery pack down and away from the device.
    • Battery pack may fall out.
    Juste pour dire 170 mm de vis c’est 17 CENTIMÈTRES de vis … apprend à te servir d’un mètre ruban
    Les miennes font 15 mm soit 1.5 cm
    Georges FAURE - Antwoord
    Merci pour votre aide
    reda khelifa - Antwoord
    Worked like a charm. My Mom's Dyson v8 was not charging after she came back from a long vacation. Installing the replacement battery with these easy instructions and the vacuum was working like new. The Serial Number and original information could not be moved over to the replacement battery. Just took a picture and put away in a folder for future reference.
    JaMa Bu - Antwoord
Conclusie
51 andere personen hebben deze handleiding voltooid.
Jasvir Dosanjh
1.671 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G5, Rose Fall 2017 Lid van UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Leden
15 handleidingen geschreven
13 opmerkingen
Great instructions!!
akcosta60 - Antwoord
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - Antwoord
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - Antwoord
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - Antwoord
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw -
straightforward easy to follow instructions battery may need a bit of a light jiggle to engage the trigger switchgear on reassembly but no problems encountered
life bank store - Antwoord
Good instructions. Easy to follow. Now we can clean our floors again! Thanks!
Christopher Bean - Antwoord
I have unsrewed three screws but my battery seems to be stuck as it will only slide out a little but won’t slide out the whole way. Any suggestions??
Yvonne Treacy - Antwoord
How long do batteries last? I’ve had mine for 3 years and I’m surprised it’s stopped working.
Zoe Pip - Antwoord
I've used mine less a dozen times; still has the stickers on it. Doesn't work. Light flashes red then blue when trigger is held. Why is it not working?!
Beverly Hall - Antwoord
What size battery do I need for Dyson Seral No. RB2-AU-KHA3272A
carmelkay - Antwoord
Got new battery for my v8 , charged it and nothing.
Gregg A Hunt - Antwoord
volendo sostituire la batteria del v8 posso metterla una piu grossa e resistente
Gianluca Serafini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 58
Afgelopen 7 dagen: 479
Afgelopen 30 dagen: 2,193
Altijd: 163,208
