Inleiding
Connection tube and brushbar will need to be removed before replacement. Housing for the brushbar may be damaged and break overtime.
Wat je nodig hebt
Turn the padlock key counterclockwise using the iFixit Opening Tool.
7 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
