Wat je nodig hebt
Remove the first flap using a flathead screwdriver or small coin to turn the mechanism to the unlocked position.
Use a T10 Torx screwdriver to remove all visible screws. Remove the secondary plate and any further screws. Note the location of the one long screw, the rest are interchangeable at this stage.
Use a T8 Torx screwdriver to remove the screw holding the spiral drive mechanism in place. This is the drive mechanism that spins the brush bar.
Use a thin flat device such as a spudger, screwdriver, or metal prying tool to lift the spiral drive piece off its axle.
You can now see one side of the ball bearing. This is where hair gets trapped if the brush bar is not cleaned regularly enough.
You can remove the hair and regrease the ball bearing from here.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
It was the final torx in the spiral drive that I hadn't noticed to get t it apart, thank you 👍
