Inleiding
If you've found yourself in a situation where the plastic air filter cover of your Dyson Supersonic HD01 has been damaged due to a drop or impact, fear not! This guide is here to help you replace the cover and get your hairdryer back in working order.
Wat je nodig hebt
Find the red dot along the top of the filter cover.
Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
Remove the filter cover by sliding it off of the body of the hairdryer.
Use a saw or sidecutters to destructively remove the broken filter cover from the cable while taking care to not damage the insulation of the power cable.
