Ga door naar hoofdinhoud
Dyson Pure Cool AM11 Oscillation Motor Replacement
Wat je nodig hebt
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: stap 1, afbeelding 1 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: stap 1, afbeelding 2 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: stap 1, afbeelding 3 van 3
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 2, afbeelding 1 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 2, afbeelding 2 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 2, afbeelding 3 van 3
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 3, afbeelding 1 van 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 3, afbeelding 2 van 2
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 4, afbeelding 1 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 4, afbeelding 2 van 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 4, afbeelding 3 van 3
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: stap 5, afbeelding 1 van 2 Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: stap 5, afbeelding 2 van 2
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 6, afbeelding 1 van 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: stap 6, afbeelding 2 van 2
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
AidenManchester
252 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
3 Leden
5 handleidingen geschreven
2Gids Commentaar
Where’d you get the motor
Jon Murch - Antwoord
any luck finding the proper motor replacement?
Kay -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 38
Altijd: 745
