Ga door naar hoofdinhoud
Dyson Pure Cool AM11 Filter Replacement
  1. Dyson Pure Cool AM11 Filter Replacement, Filter: stap 1, afbeelding 1 van 2 Dyson Pure Cool AM11 Filter Replacement, Filter: stap 1, afbeelding 2 van 2
    • Ensure the Dyson Pure Cool AM11 is turned off and unplugged from the power source.
    • Stand in front of the device. Firmly grasp the base and the top section. Twist the top section counterclockwise (to your left) to unlock it.
    • Gently lift it away from the base to expose the filter.
  2. Dyson Pure Cool AM11 Filter Replacement: stap 2, afbeelding 1 van 3 Dyson Pure Cool AM11 Filter Replacement: stap 2, afbeelding 2 van 3 Dyson Pure Cool AM11 Filter Replacement: stap 2, afbeelding 3 van 3
    • Grasp the filter housing and pull it upwards to remove it from the device.
    • Take the filter out from the housing.
    • Dispose of it according to your local waste disposal regulations.
  3. Dyson Pure Cool AM11 Filter Replacement: stap 3, afbeelding 1 van 3 Dyson Pure Cool AM11 Filter Replacement: stap 3, afbeelding 2 van 3 Dyson Pure Cool AM11 Filter Replacement: stap 3, afbeelding 3 van 3
    • Unbox your new Dyson filter. Remove any packaging or plastic wrapping.
    • Align the new filter with the housing and then put it back to the base of the device.
    • The filter should fit snugly inside the base. Ensure it is seated correctly and evenly all around.
    • Place the top section back onto the base. Align the two parts and twist the top section clockwise (to your right) until it locks into place.
    • Plug the device back in and turn it on to ensure it’s working properly with the new filter.
Conclusie
Your Dyson Pure Cool AM11 should now be operating with a new, clean filter. Regular filter replacement is key to maintaining the efficiency and longevity of your air purifier.
Zepei
255 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 45
Altijd: 170
