Ga door naar hoofdinhoud
Dyson DC58 Main Body Replacement
Wat je nodig hebt
Video overzicht
  1. Dyson DC58 Main Body Replacement, Bin: stap 1, afbeelding 1 van 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: stap 2, afbeelding 1 van 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: stap 3, afbeelding 1 van 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: stap 4, afbeelding 1 van 2 Dyson DC58 Main Body Replacement: stap 4, afbeelding 2 van 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: stap 5, afbeelding 1 van 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: stap 6, afbeelding 1 van 2 Dyson DC58 Main Body Replacement: stap 6, afbeelding 2 van 2
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: stap 7, afbeelding 1 van 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Krista St Onge
2.188 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-4, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Leden
19 handleidingen geschreven
4 opmerkingen
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Antwoord
Has anyone replaced the red release catch?
chrisashton1 - Antwoord
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Antwoord
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 52
Altijd: 12,946
