Ga door naar hoofdinhoud
Dyson DC58 Bin Replacement
  1. Dyson DC58 Bin Replacement, Bin: stap 1, afbeelding 1 van 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Bin Replacement: stap 2, afbeelding 1 van 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Bin Replacement: stap 3, afbeelding 1 van 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Bin Replacement: stap 4, afbeelding 1 van 2 Dyson DC58 Bin Replacement: stap 4, afbeelding 2 van 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ian Sloan
161 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team 2-4, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Leden
19 handleidingen geschreven
2 opmerkingen
The bin is stuck and won’t come off, although I have followed the directions above.
Marcy Altimano - Antwoord
I think the reassembly instructions should be numbered “Step 5” and printed right below Step 4. They aren’t that easy to see.
Mary Miraglia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 12,893
