Ga door naar hoofdinhoud
Dyson DC56 Motor Replacement
Wat je nodig hebt
  1. Dyson DC56 Motor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: stap 2, afbeelding 1 van 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: stap 3, afbeelding 1 van 1
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: stap 4, afbeelding 1 van 1
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: stap 5, afbeelding 1 van 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: stap 6, afbeelding 1 van 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: stap 7, afbeelding 1 van 1
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: stap 8, afbeelding 1 van 1
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: stap 9, afbeelding 1 van 1
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: stap 10, afbeelding 1 van 1
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
Conclusie
John Czerkawski
427 Reputatie
4 handleidingen geschreven
USF Tampa, Team S10-G1, Thompson Fall 2017 Lid van USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 2,862
