Ga door naar hoofdinhoud
Dyson DC56 Cyclone Replacement
Wat je nodig hebt
  1. Dyson DC56 Cyclone Replacement, Dust Bin: stap 1, afbeelding 1 van 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Cyclone Replacement: stap 2, afbeelding 1 van 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Cyclone Replacement: stap 3, afbeelding 1 van 1
    • Separate the device with the purple button.
  4. Dyson DC56 Cyclone Replacement: stap 4, afbeelding 1 van 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Cyclone Replacement: stap 5, afbeelding 1 van 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Cyclone Replacement: stap 6, afbeelding 1 van 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Cyclone Replacement: stap 7, afbeelding 1 van 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Cyclone Replacement, Cyclone: stap 8, afbeelding 1 van 1
    • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
  9. Dyson DC56 Cyclone Replacement: stap 9, afbeelding 1 van 1
    • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
  10. Dyson DC56 Cyclone Replacement: stap 10, afbeelding 1 van 1
    • Remove the rest of the cyclone screen by pulling down.
  11. Dyson DC56 Cyclone Replacement: stap 11, afbeelding 1 van 1
    • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
    • Once you have removed the screws you can remove the rest of the Cyclone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Czerkawski
427 Reputatie
4 handleidingen geschreven
USF Tampa, Team S10-G1, Thompson Fall 2017 Lid van USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Leden
11 handleidingen geschreven
1Gids Commentaar
I can’t remove the cyclone screen. Any tricks to removing?
J M - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,152
