Ga door naar hoofdinhoud
Dyson DC28 Animal Wheel Replacement
Wat je nodig hebt
  1. Dyson DC28 Animal Wheel Replacement, Wheel: stap 1, afbeelding 1 van 1
    • Flip the vacuum face down with the wheels facing up.
  2. Dyson DC28 Animal Wheel Replacement: stap 2, afbeelding 1 van 1
    • Start on the right side wheel of the vacuum cleaner
    • Remove the plastic wheel cap by sliding the tip of the metal spudger under the edge of the cap.
    • Gently pry off the plastic cap
  3. Dyson DC28 Animal Wheel Replacement: stap 3, afbeelding 1 van 3 Dyson DC28 Animal Wheel Replacement: stap 3, afbeelding 2 van 3 Dyson DC28 Animal Wheel Replacement: stap 3, afbeelding 3 van 3
    • Identify the e-clip located under the metal axle.
    • The e-clip is very small and may be hard to identify. It is a small metal ring between the metal axle and the plastic wheel.
    • Use the metal spudger to pry off the e-clip.
    • The e-clip is hard to remove and may require extra force.
  4. Dyson DC28 Animal Wheel Replacement: stap 4, afbeelding 1 van 2 Dyson DC28 Animal Wheel Replacement: stap 4, afbeelding 2 van 2
    • Slide off the plastic wheel off of the metal axle
    • Be careful when removing plastic wheel. There is a loose metal washer and black axle piston behind the wheel that can easily fall off.
    • Slide off the metal washer and black axle piston from the metal axle
  5. Dyson DC28 Animal Wheel Replacement: stap 5, afbeelding 1 van 1
    • Remove the metal axle by pulling on the left wheel. This does not take a lot of force and should easily slide out.
    • Repeat steps 2, 3, and 4 to remove the left side wheel from the metal axle.
Conclusie
Zachary Urciuoli
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 21-4, Maness Winter 2017 Lid van Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 3,018
