Ga door naar hoofdinhoud
Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: stap 1, afbeelding 1 van 1
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: stap 2, afbeelding 1 van 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: stap 2, afbeelding 2 van 2
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: stap 3, afbeelding 1 van 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: stap 3, afbeelding 2 van 2
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
Conclusie
3 andere personen hebben deze handleiding voltooid.
Quentin Klueter
164 Reputatie
1 Handleiding geschreven
Cal Poly, Team 21-4, Maness Winter 2017 Lid van Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,940
