Ga door naar hoofdinhoud
Dyson DC19 Allergy Vacuum Cleaner disassembly
Wat je nodig hebt
  1. Dyson DC19 Allergy Vacuum Cleaner disassembly, Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 1, afbeelding 1 van 2 Dyson DC19 Allergy Vacuum Cleaner disassembly, Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 1, afbeelding 2 van 2
    • Detatch the cyclone assembly from the main unit.
  2. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 2, afbeelding 1 van 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 2, afbeelding 2 van 2
    • Take the waste bin and cyclone assembly apart.
  3. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 3, afbeelding 1 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 3, afbeelding 2 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 3, afbeelding 3 van 3
    • Pull the bottom cone out of the assembly.
    • When re-assembling: there are three slots on the outer edge of the assembly that the cone matches. This is shown in picture 2. You might have to press the cone down with your thumb as in picture 3. When re-assembling, remember to fit the rubber gasket on the cone before inserting the cone in the body.
  4. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 4, afbeelding 1 van 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 4, afbeelding 2 van 2
    • Remove the gasket surrounding the bottom cone.
  5. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 5, afbeelding 1 van 1
    • Remove the seven torx screws which hold the top cover in place (one is located in the middle of the handle). You need a torx T15 driver for this.
  6. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 6, afbeelding 1 van 1
    • Remove the seven torx screws which hold the cyclone manifold in place. You need a torx T15 driver for this.
  7. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 7, afbeelding 1 van 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 7, afbeelding 2 van 2
    • Remove the manifold and the gasket underneath it.
  8. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 8, afbeelding 1 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 8, afbeelding 2 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 8, afbeelding 3 van 3
    • Flip the assembly over and remove the three plastic tabs covering the screws, then remove the screws. When re-assembling note that the screw holes align only in one way.
    • A good way to remove the tabs is to insert a small flat-head driver between the the tab and turn. (In the place marked in picture.)
  9. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 9, afbeelding 1 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 9, afbeelding 2 van 3 Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 9, afbeelding 3 van 3
    • Take the the cyclone assembly apart by pulling the two pieces away from each other. Note that these parts may be stuck together so you might have to use some amount of force. You can now remove the gasket between the parts.
    • When re-assembling note that you have to press the two pieces together really hard until you hear/feel a click.
  10. Dyson DC19 Allergy Vacuum Cleaner disassembly: stap 10, afbeelding 1 van 1
    • Everything is washable, do not use too hot water.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Sami
628 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 94
Altijd: 22,870
