Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will show you the necessary steps to replace the power switch on your Dyson DC14 Vacuum cleaner.
Wat je nodig hebt
Remove the canister from the vacuum.
Disconnect the telescopic vacuum wand.
Remove the two T15 Torx screws securing the switch cover to the vacuum.
19 andere personen hebben deze handleiding voltooid.
10 opmerkingen
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
