Ga door naar hoofdinhoud
Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement
Wat je nodig hebt
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement, Brushbar Power Button: stap 1, afbeelding 1 van 1
    • Gently pull up on red handle to separate the hose from the external hose of the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 2, afbeelding 1 van 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 2, afbeelding 2 van 2
    • Locate the 18mm four screws on the Dyson above the sticker.
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 3, afbeelding 1 van 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 3, afbeelding 2 van 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the four 18mm screws.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 4, afbeelding 1 van 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 4, afbeelding 2 van 2
    • Locate and push the grey button (where the index finger is pointing) while simultaneously pulling up on the handle.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 5, afbeelding 1 van 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 5, afbeelding 2 van 2
    • Pull on the plastic case below the power and brush bar buttons to separate it from the Dyson.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 6, afbeelding 1 van 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: stap 6, afbeelding 2 van 2
    • Slide the buttons out from the case and replace.
Conclusie
Karla Sunjara
939 Reputatie
5 handleidingen geschreven
Cal Poly, Team S13-G1, Banghart Winter 2017 Lid van Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 31
Altijd: 2,753
