Ga door naar hoofdinhoud
Dyson Cinetic Animal Ball Motor Replacement
Wat je nodig hebt
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: stap 1, afbeelding 1 van 1
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: stap 2, afbeelding 1 van 1
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: stap 3, afbeelding 1 van 1
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: stap 4, afbeelding 1 van 1
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: stap 5, afbeelding 1 van 1
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: stap 6, afbeelding 1 van 1
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: stap 7, afbeelding 1 van 2 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: stap 7, afbeelding 2 van 2
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alexandria Pompeii
400 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-5, Banghart Winter 2017 Lid van Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Leden
18 handleidingen geschreven
4 opmerkingen
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Antwoord
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Antwoord
great instructions, dismantled perfectly.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 86
Afgelopen 30 dagen: 287
Altijd: 21,758
