Inleiding
If you are using your Dyson Multi Floor Upright and there are problems or damages to the electrical cord that are causing issues with the power of your vacuum, the problem is most likely the electrical cord. The best solution to this problem is to replace the electrical cord.
Wat je nodig hebt
Press the red button on the back to release the hose and allow for easy access to the back
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
