Ga door naar hoofdinhoud
Dyson Ball Animal Power Button Replacement
Wat je nodig hebt
  1. Dyson Ball Animal Power Button Replacement, Power Button: stap 1, afbeelding 1 van 2 Dyson Ball Animal Power Button Replacement, Power Button: stap 1, afbeelding 2 van 2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: stap 2, afbeelding 1 van 1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: stap 3, afbeelding 1 van 2 Dyson Ball Animal Power Button Replacement: stap 3, afbeelding 2 van 2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: stap 4, afbeelding 1 van 2 Dyson Ball Animal Power Button Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: stap 5, afbeelding 1 van 3 Dyson Ball Animal Power Button Replacement: stap 5, afbeelding 2 van 3 Dyson Ball Animal Power Button Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: stap 6, afbeelding 1 van 2 Dyson Ball Animal Power Button Replacement: stap 6, afbeelding 2 van 2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: stap 7, afbeelding 1 van 2 Dyson Ball Animal Power Button Replacement: stap 7, afbeelding 2 van 2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Hank Wai
166 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G5, Banghart Spring 2017 Lid van Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 62
Altijd: 6,673
