Inleiding
The motherboard is found below the WiFi antenna inside the device. This guide will take you through the steps of removing the motherboard for replacement.
Wat je nodig hebt
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
