Ga door naar hoofdinhoud
Dymo LabelManager 280 Rear Case Replacement
Wat je nodig hebt
  1. Dymo LabelManager 280 Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 2 Dymo LabelManager 280 Rear Case Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Rear Case Replacement: stap 2, afbeelding 1 van 2 Dymo LabelManager 280 Rear Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Rear Case Replacement: stap 3, afbeelding 1 van 2 Dymo LabelManager 280 Rear Case Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
Conclusie
Steven Nguyen
431 Reputatie
3 handleidingen geschreven
USF Tampa, Team 6-5, Eyestone Spring 2016 Lid van USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 31
Altijd: 610
