Ga door naar hoofdinhoud
Durofix RV332 Battery Replacement
Wat je nodig hebt
  1. Durofix RV332 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Durofix RV332 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Durofix RV332 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: stap 2, afbeelding 1 van 2 Durofix RV332 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: stap 3, afbeelding 1 van 1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
Conclusie
Brennan Wade
122 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 5-5, Lauer Spring 2014 Lid van Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 2,637
