Ga door naar hoofdinhoud
Durofix RV332 Battery LED Replacement
Wat je nodig hebt
  1. Durofix RV332 Battery LED Replacement, Battery LED: stap 1, afbeelding 1 van 1
    • Remove the six 13 mm case screws with a #0 Phillips screwdriver from the side of the power screwdriver.
  2. Durofix RV332 Battery LED Replacement: stap 2, afbeelding 1 van 2 Durofix RV332 Battery LED Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic opening tool, separate the case in two to expose the internals of the cordless screwdriver.
  3. Durofix RV332 Battery LED Replacement: stap 3, afbeelding 1 van 3 Durofix RV332 Battery LED Replacement: stap 3, afbeelding 2 van 3 Durofix RV332 Battery LED Replacement: stap 3, afbeelding 3 van 3
    • Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing.
    • Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board.
    • Remove the LED from the circuit board while the solder is still melted.
  4. Durofix RV332 Battery LED Replacement: stap 4, afbeelding 1 van 2 Durofix RV332 Battery LED Replacement: stap 4, afbeelding 2 van 2
    • Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place.
    • Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Vincent
479 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 5-5, Lauer Spring 2014 Lid van Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
3 Leden
5 handleidingen geschreven
Één opmerking
Hello, I would ask the author about the type and model number of the electronic element marked as Q1 on the PCB (transistor or thyristor) on the third picture in Step 3 of this article, because mine is burnt out, and on this picture can't be read anything.
Greetings,
Plam
Пламен Петракиев - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,127
