Inleiding
The charging port is a common issue that comes with the Dualshock 4 controller as it could be worn overtime. In this guide, we will go through the steps on how to make a simple and easy repair on the Dualshock 4 CUH-ZCT1's charging port.
Wat je nodig hebt
Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
One thing I thought I'd leave here is in-case you wanted to upgrade to USB-C at the same time, this is an aftermarket product that can let you do that - https://www.tindie.com/products/mariushe...
Works an absolute treat, and the quality is astoundingly good :D
