Ga door naar hoofdinhoud
DualShock 4 CHU-ZCT2U Rear Panel Replacement
Wat je nodig hebt
  1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: stap 1, afbeelding 1 van 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: stap 2, afbeelding 1 van 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: stap 2, afbeelding 2 van 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: stap 3, afbeelding 1 van 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: stap 3, afbeelding 2 van 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: stap 3, afbeelding 3 van 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: stap 4, afbeelding 1 van 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: stap 4, afbeelding 2 van 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Rear Panel Replacement: stap 5, afbeelding 1 van 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
Conclusie
Sam Omiotek
75.409 Reputatie
288 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 101
Altijd: 2,886
