Inleiding
Use this guide to replace or fix any buttons on the Dualshock 4 controller.
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
Share button
Options button
Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
2 Trigger Springs
1 Grey Reset Button Extension
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
After the two halves are separated, place the top of the controller off to the side.
Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
Successful disassembly of the controller will result in the following three parts, respectively:
Motherboard Assembly
Front Cover
Rear Cover
Remove the rubber covering concealing the buttons with your fingers.
Use the metal tweezers to then remove the button from its slot.
96 andere personen hebben deze handleiding voltooid.
21 Opmerkingen
I pulled out my touch pad along with the motherboard when it was still attached how can I put this back in
Pull out the ribbon the way the tutorial says and then you can place the touchpad back correctly. It needs to be put in from the inside of the controller, not the outside.
This guide could be enhanced by showing the L1/L2, R1/R2 button cluster in some photos. I needed to replace the silicone grommet underneath the buttons due to Sony's design flaw of having R2/L2 press on the silicone with a blade shaped extension.
What to do If after cleaning some buttons no longer work? I was very careful when disassembling and reassembling the remote.
