Inleiding
Use this guide to replace the 3.7 lithium-ion battery inside the DualShock 4.
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
Share button
Options button
Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
2 Trigger Springs
1 Grey Reset Button Extension
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
After the two halves are separated, place the top of the controller off to the side.
145 andere personen hebben deze handleiding voltooid.
19 Opmerkingen
My Dualshock 4 wont turn on after the battery replacement.
Any idea on why this happened?
have you tried to charge it?
My samsung galaxy tab 2 7inch screen goes black help
I found a replacement battery here, you have to mod the tray a little, but it works like a champ and doubles the life.
