Ga door naar hoofdinhoud
DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement
Wat je nodig hebt
  1. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Check your controller model: stap 1, afbeelding 1 van 1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the rear case: stap 2, afbeelding 1 van 2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the rear case: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: stap 3, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: stap 3, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: stap 3, afbeelding 3 van 3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the R1 button: stap 4, afbeelding 1 van 1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: stap 5, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: stap 5, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: stap 5, afbeelding 3 van 3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 6, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 6, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 6, afbeelding 3 van 3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 7, afbeelding 1 van 1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 8, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 8, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 8, afbeelding 3 van 3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: stap 9, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: stap 9, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: stap 9, afbeelding 3 van 3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 10, afbeelding 1 van 1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 11, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 11, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 11, afbeelding 3 van 3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: stap 12, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: stap 12, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: stap 12, afbeelding 3 van 3
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the battery: stap 13, afbeelding 1 van 2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the battery: stap 13, afbeelding 2 van 2
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery: stap 14, afbeelding 1 van 1
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the reset button extension: stap 15, afbeelding 1 van 2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the reset button extension: stap 15, afbeelding 2 van 2
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: stap 16, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: stap 16, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: stap 16, afbeelding 3 van 3
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 17, afbeelding 1 van 2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: stap 17, afbeelding 2 van 2
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: stap 18, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: stap 18, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: stap 18, afbeelding 3 van 3
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the motherboard: stap 19, afbeelding 1 van 1
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
  20. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: stap 20, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: stap 20, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: stap 20, afbeelding 3 van 3
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard from the midframe.
    • Guide the analog stick covers through their cutouts in the front case.
    • Flip the motherboard over the bottom of the controller, leaving the vibration motor cables attached.
  21. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: stap 21, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: stap 21, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: stap 21, afbeelding 3 van 3
    • Grab and pull the analog stick covers straight off their modules.
    • During reassembly, rotate and press the covers until they slide onto the modules.
Conclusie
133 andere personen hebben deze handleiding voltooid.
Clay Eickemeyer
66.372 Reputatie
453 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
14 opmerkingen
So I followed all the steps, got the sticks in. But when I put the controller back together it Wouldent turn on. Do you guys have any clue as to what it could be?
blscott2270 - Antwoord
Same exact thing happened to me, just wouldn't turn back on
Andrew Purcell -
Me too and all the reconnected cables are connected correctly, but it just won’t work.
Andy Hui -
Hope you guys still keep the parts, since the problem can be resolved by following the post below successfully. :)
https://www.google.com.hk/amp/s/amp.redd...
Andy Hui -
i think you didn't put a wire in
Gabrys Holcman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 119
Afgelopen 30 dagen: 615
Altijd: 140,320
