Ga door naar hoofdinhoud
DualShock 3 Battery Replacement
Wat je nodig hebt
  1. DualShock 3 Battery Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Battery Replacement: stap 3, afbeelding 1 van 2 DualShock 3 Battery Replacement: stap 3, afbeelding 2 van 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
Conclusie
166 andere personen hebben deze handleiding voltooid.
20Gids Commentaar
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - Antwoord Deel
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - Antwoord Deel
Try Amazon Cody
linzikerner - Antwoord Deel
whats is amazon cody?
Albert Einstein - Deel
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 64
Afgelopen 7 dagen: 402
Afgelopen 30 dagen: 1,722
Altijd: 227,251
