Ga door naar hoofdinhoud
DualShock 3 Analog Stick Covers Replacement
Wat je nodig hebt
  1. DualShock 3 Analog Stick Covers Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Analog Stick Covers Replacement: stap 2, afbeelding 1 van 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Analog Stick Covers Replacement: stap 3, afbeelding 1 van 2 DualShock 3 Analog Stick Covers Replacement: stap 3, afbeelding 2 van 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Analog Stick Covers Replacement, Battery: stap 4, afbeelding 1 van 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. DualShock 3 Analog Stick Covers Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
  6. DualShock 3 Analog Stick Covers Replacement, Motherboard Assembly: stap 6, afbeelding 1 van 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  7. DualShock 3 Analog Stick Covers Replacement: stap 7, afbeelding 1 van 3 DualShock 3 Analog Stick Covers Replacement: stap 7, afbeelding 2 van 3 DualShock 3 Analog Stick Covers Replacement: stap 7, afbeelding 3 van 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  8. DualShock 3 Analog Stick Covers Replacement: stap 8, afbeelding 1 van 2 DualShock 3 Analog Stick Covers Replacement: stap 8, afbeelding 2 van 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  9. DualShock 3 Analog Stick Covers Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  10. DualShock 3 Analog Stick Covers Replacement, Analog Stick Covers: stap 10, afbeelding 1 van 2 DualShock 3 Analog Stick Covers Replacement, Analog Stick Covers: stap 10, afbeelding 2 van 2
    • Pull the analog stick covers straight up off the joystick posts attached to the motherboard.
Conclusie
86 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Reassembly doesn’t quite follow these steps in reverse order. Proper reassembly with the shoulder buttons is tricky. However, its much more simple to omit resinstalling the ‘1’ buttons until the controller housing is completely reassembled. They have one-way snapping clips on the edges, and appear designed to installed this way. Also, it’s good to double check the internal ‘1’ button switches are correctly centered inside the controller housing before4 snap in the ‘1’ buttons.
geoff - Antwoord
Question; do I have to remove the vibration motors to remove the joysticks?
efsebios - Antwoord
Thanks Andrew, your guide worked like a charm. My roomie spilled soda on the controller and the buttons were sticky. Cleaned it all up and all is good. As an aside, this controller had a rattle inside from new. I found a little black piece of plastic that looks like a bridge of sort. Now the rattle is gone too.
brent valentine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 127
Afgelopen 30 dagen: 560
Altijd: 124,528
