Ga door naar hoofdinhoud
DualShock 2 Wireless Controller Analog Stick Replacement
Wat je nodig hebt
  1. DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: stap 1, afbeelding 1 van 2 DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: stap 1, afbeelding 2 van 2
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
  2. DualShock 2 Wireless Controller Analog Stick Replacement: stap 2, afbeelding 1 van 2 DualShock 2 Wireless Controller Analog Stick Replacement: stap 2, afbeelding 2 van 2
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
  3. DualShock 2 Wireless Controller Analog Stick Replacement: stap 3, afbeelding 1 van 2 DualShock 2 Wireless Controller Analog Stick Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
  4. DualShock 2 Wireless Controller Analog Stick Replacement: stap 4, afbeelding 1 van 2 DualShock 2 Wireless Controller Analog Stick Replacement: stap 4, afbeelding 2 van 2
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
  5. DualShock 2 Wireless Controller Analog Stick Replacement: stap 5, afbeelding 1 van 1
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Roger Campbell
289 Reputatie
1 Handleiding geschreven
Texas Tech, Team S1-G1, Rauch Summer 2017 Lid van Texas Tech, Team S1-G1, Rauch Summer 2017
TTU-RAUCH-SU17S1G1
2 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 205
Altijd: 12,220
