Inleiding
Many tire pumps start to lose grip on the tire valves over time because the rubber gaskets slide against the threads on the sides of the valves, and over time this wears away part of the gasket so it no longer holds.
Many bike pumps use the same dual-valve head, and it's not immediately obvious how to repair or replace this rubber part. This rubber part is also probably common among many different pump heads- both floor pumps and frame pumps.
In this guide, I will show how to get a little more life out of the rubber gaskets merely by swapping them around. One can also replace them at this point.
Wat je nodig hebt
It's probably easier to work on the head when it is separate from the pump, so unscrew the cover on the hose at the pump head. You may need to use pliers to get enough grip.
Remove this pin however you prefer- hammer it out with a drift or other somewhat pointy object, press it out, whatever. Sorry, no pictures, you shouldn't try what I did, even if there was photographic evidence.
At first glance, it looked like a rivet or peened over head, so I tried to grind the head off of it. After grinding it down by a couple of millimeters from each end, it became clear that it was a pressed in pin, and not peened or riveted. So, learn from my mistake and do not try to grind it like I did.
Using your same pokey tool, push the gaskets out by pushing the tool along the side of each valve hole
These are all the parts of the pump head, including the pin that's been missing from previous pictures. Note the rubber ball that was hiding between two other pieces. Do not lose it or the pump will not be able to automatically switch between valves
These are the gaskets that have probably worn down. They are identical, but facing opposite directions. The bottom is for the presta valve, and the smaller hole wears down for it. The top gasket is for the schrader valve, and the larger diameter wears down on that one.
Switch the gaskets around while flipping them over, or just replace with new gaskets. As mentioned previously, these gaskets may be common among many different types of pump heads. Next push the gaskets into the pump head
Put the other pieces in the pump head ("reassembly is the reverse of disassembly"), making sure the rubber ball is captured between the other two pieces.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thank you. Shall definitely try it (using a vice)! Cheers!
Great work here; thanks for sharing!
