Ga door naar hoofdinhoud
Droid Ultra XT1080 Screen Replacement
Wat je nodig hebt
  1. Droid Ultra XT1080 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Droid Ultra XT1080 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Droid Ultra XT1080 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Gently remove SIM card tray from device using a metal spudger.
  2. Droid Ultra XT1080 Screen Replacement: stap 2, afbeelding 1 van 1
    • After SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your way around the device until all the clips are undone.
    • Be gentle with the plastic to make sure it doesn't crack or break.
  3. Droid Ultra XT1080 Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Screen Replacement: stap 4, afbeelding 1 van 2 Droid Ultra XT1080 Screen Replacement: stap 4, afbeelding 2 van 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Screen Replacement: stap 5, afbeelding 1 van 2 Droid Ultra XT1080 Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Screen Replacement: stap 6, afbeelding 1 van 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Screen Replacement: stap 7, afbeelding 1 van 2 Droid Ultra XT1080 Screen Replacement: stap 7, afbeelding 2 van 2
    • Once motherboard is removed you have successfully removed the screen from the device.
Conclusie
knoyes
785 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 26
Altijd: 766
