Ga door naar hoofdinhoud
Droid Ultra XT1080 Power Button Replacement
Wat je nodig hebt
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: stap 2, afbeelding 1 van 1
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: stap 4, afbeelding 1 van 2 Droid Ultra XT1080 Power Button Replacement: stap 4, afbeelding 2 van 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: stap 5, afbeelding 1 van 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: stap 6, afbeelding 1 van 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: stap 7, afbeelding 1 van 2 Droid Ultra XT1080 Power Button Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    $3.99
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
Conclusie
knoyes
785 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 433
