Ga door naar hoofdinhoud
Droid Ultra XT1080 Charging Port Replacement
Wat je nodig hebt
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: stap 1, afbeelding 1 van 1
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: stap 2, afbeelding 1 van 1
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: stap 3, afbeelding 1 van 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: stap 4, afbeelding 1 van 2 Droid Ultra XT1080 Charging Port  Replacement: stap 4, afbeelding 2 van 2
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: stap 5, afbeelding 1 van 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: stap 6, afbeelding 1 van 1
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: stap 7, afbeelding 1 van 2 Droid Ultra XT1080 Charging Port  Replacement: stap 7, afbeelding 2 van 2
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: stap 8, afbeelding 1 van 1
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
knoyes
785 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 29
Altijd: 921
