Ga door naar hoofdinhoud
Dremel MultiPro 395 Casing Replacement
Wat je nodig hebt
  1. Dremel MultiPro 395 Casing Replacement, Casing: stap 1, afbeelding 1 van 2 Dremel MultiPro 395 Casing Replacement, Casing: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Koop
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: stap 2, afbeelding 1 van 2 Dremel MultiPro 395 Casing Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: stap 3, afbeelding 1 van 2 Dremel MultiPro 395 Casing Replacement: stap 3, afbeelding 2 van 2
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: stap 4, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 4, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 4, afbeelding 3 van 3
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: stap 5, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 5, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 5, afbeelding 3 van 3
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: stap 6, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 6, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 6, afbeelding 3 van 3
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
    There are 2 more Torx screws under the housing cap on my model 395. I haven't figured out what size screws they are yet, but they're smaller than the other 4 Torx screws in the case.
    Richard Klein - Antwoord
  7. Dremel MultiPro 395 Casing Replacement: stap 7, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 7, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 7, afbeelding 3 van 3
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: stap 8, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 8, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 8, afbeelding 3 van 3
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: stap 9, afbeelding 1 van 3 Dremel MultiPro 395 Casing Replacement: stap 9, afbeelding 2 van 3 Dremel MultiPro 395 Casing Replacement: stap 9, afbeelding 3 van 3
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Conclusie
Één opmerking
A link to parts is always nice,
bari - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 2,124
