Ga door naar hoofdinhoud
Dremel MultiPro 395 Carbon Brushes Replacement
Wat je nodig hebt
  1. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: stap 1, afbeelding 1 van 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Koop
    • Remove the blue caps located on either side of the MultiPro using a 3 mm flathead screwdriver.
    Whstcsuze are the brushes?
    stefan mazur - Antwoord
    What size are the dremel395 brushes?
  2. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: stap 2, afbeelding 1 van 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: stap 2, afbeelding 2 van 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: stap 3, afbeelding 1 van 2 Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: stap 3, afbeelding 2 van 2
    • Carefully insert the new carbon brushes into the location of the old carbon brushes using your hands.
    I bought new two new brushes for my multipro 395 dremel, the brushes directions that can be used for my dremel and the brushes should be identical. But the new brushes springs are copper colored and the old ones are a silver color. Are the same anyway?
    Tristen - Antwoord
    Whats the correct part number for the 395 brushes, and where to get them from?
    Tonya Jackson - Antwoord
Conclusie
6 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Yeah. And if you've overheated your Dremel to the point where it quits running, the brushes may be melted in place. Disassemble the two halves of the case, and push against the brushes from the inside, using the armature. After they pop free, you'll probably find that your switch has melted as well. Return the whole thing to Dremel, and if they can't fix it cheaply, they'll give you a good deal on an upgrade to a newer model. Cheers!
Tor Matson - Antwoord
How strongly are the brush springs attached to the carbon brushes? My brushes do not look very worn, they measure .2445" (carbon block only). However, one side the spring and the brush make contact but are not held together by anything other than the spring tension. Is this a problem?
mycle85719 - Antwoord
I still have approx 1.5 cans on the brushes but it has stopped working, do they need changing?
jamessteele2 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 71
Altijd: 13,449
