Ga door naar hoofdinhoud
Dremel 4000 Shaft Lock Pin Replacement
Wat je nodig hebt
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: stap 1, afbeelding 1 van 2 Dremel 4000 Shaft Lock Pin Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Shaft Lock Pin Replacement: stap 2, afbeelding 1 van 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Shaft Lock Pin Replacement: stap 3, afbeelding 1 van 2 Dremel 4000 Shaft Lock Pin Replacement: stap 3, afbeelding 2 van 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Shaft Lock Pin Replacement: stap 4, afbeelding 1 van 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Shaft Lock Pin Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Shaft Lock Pin Replacement: stap 6, afbeelding 1 van 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: stap 7, afbeelding 1 van 1
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
Conclusie
John Cobb
1.719 Reputatie
4 handleidingen geschreven
USF Tampa, Team 15-4, Remmell Spring 2016 Lid van USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Leden
13 handleidingen geschreven
2 opmerkingen
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Antwoord
three years later and I came to the same conclusion: DUH
Randy Martin -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 117
Altijd: 12,284
