Wat je nodig hebt
Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
Using a flathead screwdriver, pry the bearing cap from the tube.
Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
The hub should fit snugly on the shaft, unable to rotate freely.
Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
