Inleiding
Most toilet repairs are easier to perform without water in the toilet tank. Use this guide to drain the tank of a traditional gravity flush toilet.
Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
Push down the flush lever.
Hold the lever down until water stops draining from the tank.
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
