Inleiding
This guide walks through the process of replacing the camera. For safety reasons, you must first follow instructions to remove the battery. After the battery is disconnected, you can follow the rest of the directions to safely remove the camera.
Wat je nodig hebt
Insert the plastic opening tool between the white back cover and black front over.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
