Ga door naar hoofdinhoud
Dopo Double Power 7 Speaker Replacement
Wat je nodig hebt
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: stap 4, afbeelding 1 van 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
mike pelosi
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-2, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 190
